XJ40 ( XJ81 ) 1986 - 1994
92 xj6 transmission
Old Mar 10, 2011 | 10:06 PM
udabes's Avatar
Default 92 xj6 transmission
CAr is shifting hard especially in reverse. Other that service or rebuilding is there anything I can do?
Old Mar 11, 2011 | 03:09 AM
Muleears's Avatar
I would do a transmission fluid and filter change with synthetic first. Do you know when the last one was done?
Old Mar 12, 2011 | 10:19 AM
MidwestJag's Avatar
udabes:
This may not apply, esp. if you are getting a clunk or difficultly putting the car into reverse; but I would research the effects of a flaky or dirty Throttle Position Sensor (TPS) on hard shifting. A bad TPS (even one that doesn't throw a code on the VCM) is known to be responsible for many a limp-mode.
I'd have your tranny or Jag specialist look at all the easy things first: TPS, fluid/filter, neutral switch, cables being out of adjustment, etc. before taking more drastic measures.
Cheers,
Scott
Old Mar 13, 2011 | 04:38 PM
mrtalkradio's Avatar
When your car is running is the little tranny orange light on in the upper left of your instrument panel?
Old Mar 14, 2011 | 09:53 AM
udabes's Avatar
Default Jag trans
No the trany lite is not on.
Old Mar 14, 2011 | 08:19 PM
roger ele969c's Avatar
How long has it been happening Mine has a hard shift between 2nd and 3rd and the light comes on at irregular intervals, when it hardly runs. Disconnecting the battery gets it back running until the next time. Any ideas would be appreciated......Roger.
Old Mar 15, 2011 | 01:23 PM
udabes's Avatar
Cheers,
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
rusty37
Apr 5, 2020 07:40 PM
SouthernGypsy
Sep 23, 2015 04:06 AM
ahunt4
Sep 14, 2015 08:17 PM
