XJ40 ( XJ81 ) 1986 - 1994
93 XJ6VP Brake shift interlock
Old Apr 1, 2013 | 10:57 PM
Firewrench's Avatar
Default 93 XJ6VP Brake shift interlock
Since picking up the Green Machine, the brake shift interlock has been dodgy. This morning I realized the brake lights weren't coming on every time the brakes were applied. I removed the brake light switch and was able to get some contact cleaner in the "sealed" micro-switch by spraying in where the wires go in. A couple of applications and some air dry time and we now have 100% lights and interlock operation. YEAH!!!!!!
Old Apr 2, 2013 | 08:05 AM
MidwestJag's Avatar
Thank you! I may try this before going to replace the switch on my '94 which has the same - annoying - problem.
Scott
Old Apr 2, 2013 | 09:26 AM
Firewrench's Avatar
Scott
You're welcome. I'd suggest hiring a midget gymnast to remove the switch. Tight quarters under the dash. I removed the knee bolster and support to gain access and still was a bit frustrating. 7mm bolt and 8mm self locking nut on bottom requires two hands. Upper bolt didn't need to be touched. Good luck!
Old Apr 15, 2013 | 09:44 PM
Firewrench's Avatar
Well, about 3 days later, back to intermittent brake lights. Ordered a switch from an unnamed source and waited close to two weeks for delivery. No part. Called to check status and told "we don't have one to ship you, we've been looking but nothing available." Even better, will take 3 to 7 days to credit my card with a refund. Can I use the word "douche bag" on this forum? What a rotten way to do business. Guess who isn't getting another order from me!
Old May 22, 2013 | 08:03 AM
tomcat59alan's Avatar
Default brake switch
Just a question,is it easier to remove the brake pedal first to gain access to the brake switch.Looks like one bolt and a clevis pin to remove it.
hamilton7550
Jul 30, 2021 11:29 PM
neruda
Oct 18, 2015 01:19 PM
Roger95
Sep 25, 2015 02:05 PM
reb1999
Sep 19, 2015 07:30 AM
GGabriel
Sep 18, 2015 08:44 PM
