XJ40 ( XJ81 ) 1986 - 1994
'94 Souvereign key locks driver door but won't unlock it
Old 02-15-2011, 09:35 PM
Steve W's Avatar
Default '94 Souvereign key locks driver door but won't unlock it
Am I missing something? The passenger door can be locked and unlocked with the same key.
Old 02-16-2011, 04:05 AM
Cadillac's Avatar
I am moving your thread off to the proper area, my input is I think you should also try it with a master key that's the bigger one . However, central locking only works with the driver's door which is very frustrating lol
Old 02-16-2011, 08:36 AM
Received 7,896 Likes on 4,770 Posts
The door lock is either worn or someone replaced it and you don't have the correct key.
Any TIBBE key will LOCK but the correct key is needed to UNLOCK.
You can read the key code through the slot in the lock assy (See FIG 6 in the TSB 76-64) so you could compare the right and left as well as reading the key itself.
I tried to attach the TSB but it is 2.8MB and it did not upload
bob gauff
jerry_hoback (10-06-2020)
Old 02-16-2011, 11:29 AM
Received 1,231 Likes on 716 Posts
I sometimes have problems with that file.
However, try this Steve W --- S76-64
Old 02-17-2011, 08:31 AM
The reason it is so large is that I created it with ADOBE 4.0 as a multiple page, single .pdf by scanning the paper documents and importing them into MicroSoft WORD and converting it to .pdf (it was the only way I could think to do it)
I should re-scan the paper to a newer version and reduce the file size.
I'll look through my 3 ring binders for really old TSBs to see what else I can find.
bob gauff
D.K
12-10-2023 02:05 AM
99xk8guy
06-05-2023 06:28 AM
Wolfy
04-06-2019 10:40 PM
XJsc-guy
11-23-2015 01:56 PM
tberg
09-07-2015 07:32 AM
Quick Reply: '94 Souvereign key locks driver door but won't unlock it
