XJ40 ( XJ81 ) 1986 - 1994
abs and brake warning...
Old May 16, 2025 | 01:08 AM
mickvic's Avatar
Default abs and brake warning...
Had to hit the brakes a bit harder than normal....I went past the point of usual resistance to new territory on the pedal. Thankfully the car stopped as there was a guy actually running out inn front of me with a stop sign. Im sure they are not supposed to do that.
Now with braking the its the same pedal as before but the abs warning , and the brake light are on. Bit concerned about how she might perform in an emergency stop. Replaced the brake accumulator ball few years ago with a mercedes one.
Be interested in advice from the group as to next step. Fluid level is fine. The brake pump (i think its called) is running but it has a deeper sound and does not turn off after little while like it used to.
Old May 16, 2025 | 09:34 AM
motorcarman's Avatar
ABS test info.
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 5, 2025 | 06:53 AM
mickvic's Avatar
Replaced the accumulator ball with a gm one, screwed straight in , warning lights out, sharp brakes working beautifully. ....bit of driving and overnight situation lost all power assistance....huge pressure needed to make the brakes work even a bit.
Caannot hear brake pump with its usual whirring sound. At all.
Can hear a click when I turn the ignition to on (no starter)
Any thoughts on what the problem could be here , most likely, and how to fix it? Mick
Old Sep 9, 2025 | 09:25 PM
mickvic's Avatar
Anyone got hints as to fuse location for the brake pump...and any relays? Thanks
Old Sep 15, 2025 | 06:22 PM
The electrical guide has all that info.
JagRepair.com - Jaguar Repair Information Resource
radjag1
Apr 24, 2025 02:21 AM
benzjag
Nov 2, 2022 06:08 PM
ESTS
Mar 21, 2022 10:20 AM
Duke85
Jun 21, 2020 01:26 AM
Roland M
XJ40 ( XJ81 )
Jun 21, 2015 08:58 PM
