XJ40 ( XJ81 ) 1986 - 1994
Alarm problems
Old May 10, 2013 | 11:38 AM
EFrazen's Avatar
Default Alarm problems
My car is having issues. My alarm started going off today for no reason so I turned it off under the arm rest and it still going off. Took the cables off the battery for 15 sec and it still went off when i reconnected the cable to battery. so now i disconnected the battery for more then 10 mins and it still at the moment disconnected. What could be the problem. Oh yeah i also took the battery out of the remote on the key chain after it did nothing to help the situation. When the key is in and the car is started it keeps beeping.
Old May 10, 2013 | 12:29 PM
Lawrence's Avatar
Not that it's much help, but on my 94 the alarm switch in the armrest in the "off" position only partially disables the alarm. Some functions are still active and the alarm will still sound with the switch off.
Possibly an intrusion sensor is stuck or malfunctioning? I had an issue where the reading lamps in the back door pillars (VDP trim) triggered the alarm when they were extended - scared the **** out of me at the time!
Sorry I can't be of more help - afaik the alarm unit is located in the roof console that contains the sunroof switch, try disconnecting it there maybe?
Old May 10, 2013 | 01:05 PM
EFrazen's Avatar
Well thanks for the info but I got so upset at it I took the keys remote and pushed it in for about 2 sec and it went off to my surprise. I felt so stupid. ha ha ha
Old May 12, 2013 | 12:27 AM
humblb's Avatar
Need entry handheld alarm remotes for my 1988 xj6. Does anyone know where I can find?? Thanks
Bigvettefreak
Sep 6, 2015 04:27 PM
mcdutch
Sep 4, 2015 03:38 AM
philwarner
Sep 3, 2015 10:14 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
