XJ40 ( XJ81 ) 1986 - 1994
The answer is probably already out there, about my xj40 air con fault that is
Old Jan 13, 2010 | 11:53 AM
Hi Tod if I could email you some of this cold in exchange for some of your heat, believe me I would.
Have you checked the main connector to the aircon ECU behind the panel near your left foot. (Australia RHD correct). It may have come loose or even have dropped off.
Also there are relays inside the blower units themselves, but you need to remove them to get to these.
That's about it for me and Aircon, never use it, can't afford the petrol.
Old Jan 16, 2010 | 10:21 AM
motorcarman's Avatar
There was a TSB issued in the early 90s to replace the micro-switch in the climate control panel (1988 to 1992). The last TSB I have is 82-38 ammended 7/95 and it has instructions for repair. Jaguar offered a switch repair kit, (JLM11240) but a micro-switch and 2 (2-56 screws) can be sourced locally at electronic parts supplier.
bob gauff
Mugatu
22
Jun 23, 2020 01:50 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
OkieTim
Sep 2, 2015 12:48 PM
