XJ40 ( XJ81 ) 1986 - 1994
Boot Lid Alignment Problem
Old Aug 8, 2017 | 10:18 PM
hopeless jag owner's Avatar
Default Boot Lid Alignment Problem
i cant get my boot to mesh when i close the lid
a situation occured where the goose neck shape that is attached to the vehicle and interacts with the closing lid does not mesh as it should no matter what position i put it in i have had the goose neck out a dozen timers trying different positions then closing the boot to no avasil im doing something wrong but i cant see what it is mark
help
Old Aug 18, 2017 | 01:26 PM
Rob Evenson's Avatar
Originally Posted by hopeless jag owner
"the goose neck shape that is attached to the vehicle and interacts with the closing lid"
Hopeless,
I'm not sure what piece you are referring to when you use "goose neck". Are you referring to the neck for the fuel tank, or are you referring to the hinge which attaches the fuel fill lid to the body of the car, also sometimes called a goose neck, or are you referring to the hinges for the boot lid which attach to the body Perhaps you could attach a picture of the part.
This thread originated on the subject of the fuel filler lid assembly, therefore a bit confused on what you are asking.
Old Aug 19, 2017 | 02:27 PM
Don B's Avatar
Hi Mark,
I have moved your post from an old thread related to the boot latch to start your own new thread, since it is not the latch that is your problem.
Without knowing the year and model of your Jaguar it's impossible to give you a specific response, but from your description I gather that what you are calling the gooseneck is the boot/trunk lid hinge, which is part 2 in the XJ40 diagram below:
One typical cause of boot lid alignment problems is a bent hinge or boot lid panel due to the lid having been forced onto an object in the boot that was too tall to allow the lid to close properly. Is it possible your hinge is bent, or the lid is twisted?
If you'll let us know the year and model of your Jag I'll make sure your thread is in the correct forum.
Cheers,
Don
Digital Will
Feb 21, 2026 05:58 PM
JimC64
Sep 22, 2025 02:52 PM
S Daddy
Oct 9, 2016 10:26 AM
sjuraud
Aug 28, 2010 02:11 PM
XJ40 ( XJ81 )
Oct 27, 2006 01:02 AM
