XJ40 ( XJ81 ) 1986 - 1994
brass thing with a vacuum attached, behind fuse panel
Old Oct 4, 2013 | 10:54 PM
jagnoob's Avatar
Default brass thing with a vacuum attached, behind fuse panel
theres a brass colored thing RIGHT behind the fuse panel on the passenger side, behind the lower panel of the dash. it has a vacuum attached to it, but the vacuum is cut. pic is uploaded.. no idea where this is supposed to go
Attached Thumbnails brass thing with a vacuum attached, behind fuse panel-1004131715a.jpg
Old Oct 4, 2013 | 11:05 PM
Big_Walleye's Avatar
That is a vacuum actuator that I believe operates the passenger side recirc door. There is a small vacuum line that should be plugged into it. The same thing happened on my car and the line is hard to find again if it gets unplugged.
Old Oct 4, 2013 | 11:43 PM
jagnoob's Avatar
what do you mean "recirc door"? where the heat comes out?
Old Oct 4, 2013 | 11:45 PM
Lawrence's Avatar
side face vent
Old Oct 4, 2013 | 11:48 PM
jagnoob's Avatar
oh ok gotcha thanks
Old Oct 4, 2013 | 11:52 PM
Lawrence's Avatar
well not the side vent itself but the door that opens/closes to send air to that face vent.
Old Oct 5, 2013 | 12:04 AM
The recirc door opens so that the climate control system can draw air from inside the cabin instead of drawing air from outside. If you put the a/c on high the door above the passenger's feet should open if the vacuum line is connected properly.
DpezXK8
Aug 27, 2025 08:55 AM
FrickenJag
Jun 16, 2025 02:15 PM
trosty
26
Dec 18, 2022 06:40 PM
redrover41
23
Sep 25, 2015 01:33 PM
motorhead69
Sep 9, 2015 10:04 AM
