XJ40 ( XJ81 ) 1986 - 1994
Cabin air filter and leaking air conditioner condenser coil
Old May 24, 2021 | 04:08 PM
Rick Jag Owner's Avatar
Default Cabin air filter and leaking air conditioner condenser coil
I have a 1992 Jaguar XJ6 that I am finding more and more puzzling each time I work on it. I want to change the cabin air filter but don't know where it is. I have a leaking air conditioner condenser coil that I have to change out but it looks like I have to dismantle the front end.
Any information to help me with the repairs is greatly appreciated.
Old May 24, 2021 | 09:30 PM
motorcarman's Avatar
CABIN AIR FILTER??????? you must be kidding!!
The two cabin blowers just move air from inside or outside depending on the RECIRC button or temp setting.
Old May 25, 2021 | 01:09 AM
Lawrence's Avatar
The condenser is easily removed by undoing the top radiator/condenser mounting plate. (5? torx screws) The condenser just lifts out.
Of course you will have to undo the refrigerant connections before lifting it out. Use care undoing the hose connections, remember this is aluminum and it's easy to twist off the pipes if you don't hold both ends of the connection with wrenches.
Larry
Jerry Redmond
US Lower Atlantic
Oct 23, 2020 09:25 AM
nathan88xj6
XJ40 ( XJ81 )
May 24, 2011 12:24 AM
Kevin Rambold
Jan 22, 2011 09:32 PM
