XJ40 ( XJ81 ) 1986 - 1994
Car won't start
Old Nov 25, 2011 | 07:35 PM
lazzytan's Avatar
Default Car won't start
Hi all$ hope everyone had a good holiday!
So here's where I'm at. Finally got the car running pretty good actually (needs lots of love, lots of love) anyways so here is what i have done so far:
•Replaced fuel pump and filter
•Ignition coil, spark plugs, wires and distributor cap
•Fuel pressure regulator
•Cleaned injectors
•Air filter
•New battery
Here's the problem the car will start once a day or I should say it won't start when engine is hot. It idles perfect and runs great but when I shut the engine off it will not start again :# also the spark plugs are burning really quick. I am very very frustrated with this car. And can think of nothing else what am i missing? What else should I look for?
THANKS A LOT IN ADVANCE
Old Nov 25, 2011 | 10:48 PM
Jagfix38's Avatar
A box of matches and a carton of beer!
Did you replace the fuel non-return valve at the same time as you replaced the fuel pump? It's a check valve that fits onto the end of the fuel pump and greatly assists pressure regulation especially with the symptom you describe.
Also have you done a compression test on all 6 cylinders?
Old Nov 26, 2011 | 08:03 AM
mrtalkradio's Avatar
CPS! Read the entire thread with the title CPS. There is enough information there to get any car started, at least until the next time it wont
Old Nov 26, 2011 | 12:40 PM
MidwestJag's Avatar
lazzy:
You should put the make/model/year/etc in your signature line so that we don't have to go fishing for it. But I'm guessing this is your '88 vdp...
A flaky CPS is notorious for causing the intermittent non-start. I think they can be bench tested; but a replacement might be in order. It would certainly eliminate a serious possibility. Alas, new ones are about a hundred bucks.
Just last week or the week before I heard Click and Clack on NPR suggest somebody replace their fuel pump relay because she was experiencing the same symptoms as you. This was also my very first 'fix' when I originally got my car. Relays can apparently become flaky with age and heat.
Scott
Old Nov 26, 2011 | 12:42 PM
MidwestJag's Avatar
PS... Are you sure you are getting good, strong, and consistent fuel pressure at the rail?
Scott
Old Nov 26, 2011 | 06:15 PM
lazzytan's Avatar
Thanks guys for the help n moral support! I will certainly check into the cps. Is there a way to test them? In the car?
I think Im getting good pressure by I have never actually measure the pressure just made sure fuel was comin out of all injectors. What kills me is that the car is guaranteed to start and run perfect it just won't start again until completely cool I'd say bout 4 hours or so.
It is a 88 vdp
Thanks again u guys!!!
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
1964Daimler
Sep 2, 2015 11:41 PM
Drew2006
Aug 28, 2015 04:22 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
