XJ40 ( XJ81 ) 1986 - 1994
Check engine light, code Fuel 17
Old Feb 26, 2015 | 01:15 AM
Palmero's Avatar
Default Check engine light, code Fuel 17
Hello there.
1992 Vanden Plas, 134K miles. When cold, if I don't pump the gas slightly, I get a check engine light with fuel code 17 (throttle potentiometer). Runs fine after that and I never get the check engine light while warm. Some times when cold, the engine dies, but starts right away.
So, is it the throttle positioning sensor as indicated by the fault code, or maybe some other sensor?
Thanks.
Old Feb 26, 2015 | 11:29 AM
Lawrence's Avatar
Try cleaning the TPS connector and see if that makes a difference - FF17 is a throttle pot fault code.
Larry
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
big d
Sep 3, 2015 07:37 PM
cheaperts
Aug 30, 2015 06:48 PM
