XJ40 ( XJ81 ) 1986 - 1994
Climate control
Old May 3, 2018 | 02:45 PM
Richard A. Stolfa's Avatar
Default Climate control
The heat won't turn off on my 1988 XJ40
Old May 3, 2018 | 03:37 PM
Don B's Avatar
Hi Richard,
I believe that in your '88 there is a separate heater water control valve mounted in the heater hose near the firewall in the engine compartment, part 1 in the diagram below. Its default position is open, allowing hot coolant to circulate through the heater core. It is shut off by vacuum, so if the vacuum hose is cracked or detached from the small elbow pipe visible on top of the valve, or the vacuum source is clogged, the valve will always be open and you'll have heat at all times:
Cheers,
Don
Old May 8, 2018 | 07:10 AM
Than you. I'll look for this. Does the valve ever go bad? I see they are available at a reasonable price.
Old May 8, 2018 | 08:42 AM
Don B's Avatar
Yes, the valves do fail, but check the vacuum hose and if you have a vacuum gauge test it for proper vacuum to the valve.
Cheers,
Don
JimC64
Sep 22, 2025 02:52 PM
metalmarty
Nov 14, 2016 09:59 AM
Flakster
Oct 22, 2016 11:04 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
