XJ40 ( XJ81 ) 1986 - 1994
Coolant reading sits at 50?
Old Dec 18, 2021 | 01:18 AM
Rekin0m's Avatar
Default Coolant reading sits at 50?
Coolant meter sits closer to 50 barely see it budge and if it does it doesn't move much at all Is this normal? Bad temp sensor? This pic is just an example of what the gauge looks like, if you look over on the l
eft side of the dash you'll see the different levels.
Old Dec 18, 2021 | 08:34 PM
motorcarman's Avatar
The AJ6/16 engine cooling system thermostats fail OPEN.
Maybe replace the T-Mostat and report back? (is the heater putting out hot air?)
Old Dec 18, 2021 | 10:32 PM
Rekin0m's Avatar
Default Negative
Heater is not blowing hot air
Old Dec 18, 2021 | 10:34 PM
Rekin0m's Avatar
Circuit 1 also has a failure and circuit 3 as well, I did a quick check and a couple of fuses are blown, that was gunna be the first thing I checked into fixing
Old Dec 21, 2021 | 03:15 AM
Brett J's Avatar
Is your oil pressure gauge slow to respond, like a 5 second time delay in both increasing in pressure with engine revs and the decrease in pressure when back down to idle?
Mine is with the digital dashboard.
As for the temp, mine sits 1 to 2 notches either below or above the 90 mark. At idle with the AC on and a hot day it sits 1 to 2 notches above the 90 mark and the electric aux fan will be running.
Driving along with the good airflow its below the 90 mark.
Also the snow, winter panels at the back of the electric aux fan have been removed.
F1Virginia
XF (X260)
28
Sep 4, 2024 12:32 PM
Clackavosticus
Nov 24, 2021 06:16 PM
Justtttttom
Jan 10, 2021 06:55 PM
chrisleg
Aug 29, 2018 04:06 PM
Kenny Bee
Jan 3, 2013 08:53 PM
