XJ40 ( XJ81 ) 1986 - 1994
EAC7905 failure
Old Dec 20, 2021 | 07:35 PM
Roger95's Avatar
Default EAC7905 failure
I've recently replaced the failed EAC7905 EGR solenoid in my 90 Majestic. Using my Fluke multi meter I checked the old and new solenoids. The failed solenoid checked out at 151 ohms, with the new replacement checking out at 40 ohms.
Old Dec 20, 2021 | 07:56 PM
Roger95's Avatar
Default Rain shield rubbing inside of brake rotor.
I finished replacement of front brakes (pads and rotors) and wheel bearings in my '90 Majestic over the weekend. The left front rain shield is rubbing the inside of the brake rotor during right turns. In all of the brake jobs I've done, in all of the years I've done them I"ve never had this problem. I'll be checking this out in the AM. Any ideas?
Old Dec 21, 2021 | 12:53 AM
Lawrence's Avatar
Not sure what you mean by the "rain shield" - have you bent or distorted something?
Larry
Old Dec 21, 2021 | 03:06 AM
Brett J's Avatar
The heat / dust shield? I dont even think they are really needed, you could probably just remove it
Old Dec 21, 2021 | 10:03 AM
Roger95's Avatar
Yes, the sheet metal cover to the rear of the hub. I just removed the bearings and so forth as usual. I'll be "playing' with it this afternoon. I am considering some careful realignment with my BFH. The entire situation is puzzling. I never had a problem with it, never hit anything, no corrosion, just removed the old parts, installed the new without any trouble. Now, on right turns the rotor rubs on the shield. This PM I will snug up the bearing nut a bit and...?
Old Dec 21, 2021 | 11:21 AM
jerry_hoback's Avatar
I get that problem... sometimes. Its usually a matter of reaching around the installed wheel and pushing inward on the dust shield. Its just tin and will bend very easily. It is also easy to bend when moving other heavy parts around during repairs....
Old Dec 21, 2021 | 01:19 PM
Roger95's Avatar
Duh, I didn't torque the lug nuts...
Old Dec 22, 2021 | 05:24 AM
Easy fix! Be happy!
Old Dec 24, 2021 | 06:54 PM
Roger95's Avatar
I am happy, but it's difficult to not feel stupid when I do stupid. BTW, a full front end rebuild is on my schedule.
5speedusa
Jul 30, 2025 12:11 PM
rjesq
Apr 6, 2018 12:55 PM
93greenconv
Jun 29, 2013 06:26 PM
Scotlad
Nov 13, 2012 11:34 PM
roger ele969c
XJ40 ( XJ81 )
21
Jun 20, 2012 08:14 PM
