Prestone PRIME conventional 50 50 coolant. Thoughts?
Old Aug 26, 2018 | 09:07 PM
chrisleg's Avatar
Default Prestone PRIME conventional 50 50 coolant. Thoughts?
Hello all!
Hope everyone is having a good weekend.
Been looking for some repalcement coolant and came across PRIME Conventional. At first i ignored it as i have never seen it before but then realised it was by Prestone so figured it must be ok right?
I had a read on the website and it says suitable for up to one year. Really?? Thats it?? I was told that coolant should be flushed every 2 / 3 years.
Any thoughts / recommendations for this Coolant?? Worth it?
I am running an 87 XJ6
Thank you
Old Aug 27, 2018 | 08:03 AM
Yellow series3's Avatar
XJ6s are known to have sort of weak cooling systems so I would not cut corners. Follow factory recommendations carefully and use the best quality materials you can find. And be real sure to keep it topped up properly.
Old Aug 27, 2018 | 08:13 AM
Doug's Avatar
Just use ordinary old fashioned green Prestone and be done with it . It'll work fine with no guessing or concerns. If you're starting with a clean system....really clean....a flushing every 3 years should be fine. Make the interval 1 or 2 years if you're not sure.
Old Aug 27, 2018 | 10:18 AM
JagCad's Avatar
Yup. Doug's method has worked for decades in all kinds of critters..
Carl
Old Aug 27, 2018 | 12:46 PM
chrisleg's Avatar
Thanks doug.
Which one is it? The standard yellow bottle?? There is a long life, which i was told not to use, I looked on Amazon and nothing but the long life stuff comes up!
Much appreciated if you have a link
Chris
Old Aug 27, 2018 | 01:18 PM
They call it extended life just as a marketing gimmick. About $10 at Wal-Mart. Yellow bottle. I suggest using the full strength and not diluted. Find the system capacity, divide by 2 and put that much in. Then top it up with distilled water. If you use the prediluted you might not wind up with a true 50/50 mix.
look on YouTube for instructions on flushing the system. Keep flushing until what comes out is pure clean water. I had to flush mine about 5 times until it ran clean. Drain, plug and fill up with antifreeze and distilled water.
Old Aug 27, 2018 | 01:47 PM
chrisleg's Avatar
this one?
https://www.walmart.com/ip/Prestone-Extended-Life-Prediluted-Antifreeze-Coolant/16879961?wmlspartner=wlpa&adid=2222222222801756329 5&wl0=&wl1=g&wl2=m&wl3=40840067792&wl4=pla-78653338832&wl5=9060286&wl6=&wl7=&wl8=&wl9=pla&wl1 0=8175035&wl11=online&wl12=16879961&wl13=&veh=sem
are silicones bad for the radiator and other components?
you can get so side tracked with info!
I am actually getting a guy to flush and refill with antifreeze and distilled water mix this week. He suggested getting prestone 50/50 if I needed to top up.
Somewhere on the internet someone said just water. That cant be right though????
Old Aug 27, 2018 | 04:31 PM
Sorry for the confusion. If you have someone that knows what they are doing it is a moot point but what I tried to say is if the system holds 4 gallon and you drained it, put 2 gallon antifreeze in and then the rest distilled water. That gives you a 50/50 mix which is what you want. If you have a jug in your garage to top it up now and then, either full strength or 50/50 blend will work fine. Just use the same brand.
Old Aug 27, 2018 | 08:50 PM
chrisleg's Avatar
Thanks Yellow Series 3
I should have mentioned it but i was flip flopping as to wether i should get it done or not. But he has a day free now so i figured i would bite the bullet and go for it.
Understand about the coolant and same brand. Would there be any reason I would top it up with water??? Just something another guy told me but It confused me as i figured water is corrosive so why would i top up with even MORE water???
Thanks again!
Old Aug 28, 2018 | 09:54 AM
JagCad's Avatar
Cris:
You are right at times, the flood of information clouds the answer.
1. The link you quoted includes these words "prediluted". Handy, yeah, but at a cost.
It merely means half glycol and half water. You pay a lot for water!!!
2. Yellow has it down pat.
3. Your guy's suggestion to top off with 50/50 makes some sense. It is ahndy and maintains the proportion
4. Adding water does dilute the mix. But, if not in huge amounts, harmless. Distilled, of course.
5. Most rarely need topping off. I've topped off with any of the three options.
A. Pure Glycol
B. Distilled water.
C. The expensive 50/50 mix.
All has been well.
Almost all brands are glycol based, it is the additives that differ. Some compatible, others not so much.
Caveat. don't spill the glycol. Animals love its sweet taste. Can be fatal!!!
That is my main issue with driveway flushes. As well as not good for ground water.
Cart
Old Aug 28, 2018 | 02:36 PM
chrisleg's Avatar
Originally Posted by JagCad
Cris:
A. Pure Glycol
B. Distilled water.
All has been well.
Cart
Thanks Cart
Yeah i figured i would hold back on trying to do it myself this time around. Need to get more comfortable and the right equipment. Slowly slowly
Would you say that even the Long Life stuff is the same as the regular??? And if so why do they market as such??
Thanks again fella!
Old Aug 29, 2018 | 07:34 AM
JagCad's Avatar
You might just Google up "long life glycol based anti-freeze".
Glycol is glycol. there is one version that is slightly different. Marketed at least a tone time under the Sierra label. Said to be "safer" for anima; ingestion.
But, I think the long life has to do with the inhibitors. Anti freeze is a common name.
And, yes it freezes at a much lower temperature than water. But, the inhibitors to resist corrosion are equally important.
Don't know where you are in CA. But in most of our state we rarely see a freeze bad enough to crack heads and blocks. In the high Sierras, yes,
As you mentioned a NAPA store in your neighborhood, go there if you decide to DIY!!
Gee, I misspelled my own name. I can spell, but stiff AM fingers let me down.
Carl
Old Aug 29, 2018 | 04:06 PM
chrisleg's Avatar
Hahah I thought you had. But I figured just go with it hahah
I guess my main concern is in having too many selicants that will degrade my car system quicker as
so been spending too much time reading up on types etc. Maybe I am over thinking it??
thanks again Carl!
clam
May 17, 2014 12:07 PM
Ledhead
Jun 21, 2011 09:19 AM
cory620
Jul 15, 2010 09:19 PM
jagxkrtoofast
Dec 3, 2009 02:29 PM
