XJ40 ( XJ81 ) 1986 - 1994
correct lifting points engine removal
Old Jun 4, 2010 | 02:40 AM
granpapafred's Avatar
Default correct lifting points engine removal
Have a replacement engine for my 90 xj6, plan to replace all hoses belts and what ever else is recommended on this forum while engine is on ground. The replacement has 70,000 previous owner verified miles. The only thing missing on the engine is the hyd. pump, so I plan to use my old one, The new engine only shows normal dirt and grease, no leaks of consequence, what all should I do while it is out of the car? Where do I attach a lifting devise, and what config device is recommended?
philwarner
Dec 6, 2021 07:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
1964Daimler
Aug 31, 2015 06:37 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
