Help please, my dash LED system has failed, need to send to ATLANTA SPEEDOMETER, for repair, but!!! How or where to remove fasteners, to access cluster to send off . ??? No ; You Tube. , NO videos are to be found, don’t have factory shop manual, owners manual has nothing on repair. Please show way to a video or directions how to remove from leather cluster cover. Thank you Help on LED CLUSTER REMOVE FROM DASH
Welcome Craig.
Don't Panic! Contrary to most things Jaguar, this is an easy one. Remove the knee bolster, and the metal behind that- all phillips screws on mine. Then 2 screws each side, I think 8mm, and 4 electric plugs, all different so no confusion. Be careful of the forward inboard mount screw with the dash prop rod, the nut on it Will fall down behind the carpet never to be seen again.. ask me how I know. The whole thing will pull out as a unit. Bobs yer uncle.
