XJ40 ( XJ81 ) 1986 - 1994
Dash head, Cluster remove 1989 XJ6 VP, HELP
Old Oct 25, 2022 | 01:22 PM
Craig Geske's Avatar
Default Dash head, Cluster remove 1989 XJ6 VP, HELP
Help please, my dash LED system has failed, need to send to ATLANTA SPEEDOMETER, for repair, but!!! How or where to remove fasteners, to access cluster to send off . ??? No ; You Tube. , NO videos are to be found, don’t have factory shop manual, owners manual has nothing on repair. Please show way to a video or directions how to remove from leather cluster cover. Thank you
Help on LED CLUSTER REMOVE FROM DASH
Old Oct 25, 2022 | 01:38 PM
Craig,
As you have already posted an Intro, I've moved your question to XJ40 forum for advice from members with the same model.
Old Oct 25, 2022 | 03:18 PM
bubbasgarage's Avatar
Haynes manual chapter 11, item 25, Instrument cluster housing -removal and refitting.
File Type: pdf
Old Oct 25, 2022 | 04:35 PM
jerry_hoback's Avatar
Welcome Craig.
Don't Panic! Contrary to most things Jaguar, this is an easy one. Remove the knee bolster, and the metal behind that- all phillips screws on mine. Then 2 screws each side, I think 8mm, and 4 electric plugs, all different so no confusion. Be careful of the forward inboard mount screw with the dash prop rod, the nut on it Will fall down behind the carpet never to be seen again.. ask me how I know. The whole thing will pull out as a unit. Bobs yer uncle.
bobby stef
XJ40 ( XJ81 )
21
Sep 24, 2016 09:36 AM
Tracy Weiland
Aug 28, 2016 11:34 PM
car5car
Jun 26, 2016 05:33 PM
brockallentaylor
XJ40 ( XJ81 )
Sep 16, 2009 03:07 PM
androulakis
Jul 2, 2007 10:23 AM
