XJ40 ( XJ81 ) 1986 - 1994
Dizzy
Old Jun 28, 2019 | 06:53 AM
Evil Elsie's Avatar
Arrow Dizzy
Hello - me again...
This should be a simple one but I've done a search and can't find the answer.
What model of Lucas Dizzy will my AJ6 have..?? I'm guessing a 45D6 but i'd like to know for certain.
Whilst the car's in bits (and i'm in the doghouse) I think i'll replace Dizzy Cap, Rotor, HT Leads, King lead and maybe the Coil.
Thanks in advance,
Dave
Old Jun 28, 2019 | 10:56 AM
Lawrence's Avatar
Pretty sure you don't need the distributor model number to swap out the bits you're planning - you'd be better off getting the Jag part number which you can get here:
https://www.jaguarclassicparts.com/uk/jaguar-xj6-parts
Larry
Old Jun 29, 2019 | 05:30 AM
Evil Elsie's Avatar
Thanks Lawrence,
After a bit of digging and using the Jaguar Part numbers from the link you provided it looks like;
Distributor - DBC 2690 = Lucas 41990
Dizzy cap - JLM 150 = Lucas DDB 130 (supersedes Lucas 54403235)
Rotor arm - JLM 381 = Lucas DRB121 or QUINTON HAZELL: XR168 or INTERMOTOR 47651S or Facet 3812RS or MOTAQUIP LVRA355
As I found when looking for 14x Cylinder Head Bolts - searching on the Non-Jaguar part number usually finds cheaper prices...
Cheers, Dave.
Old Jun 29, 2019 | 08:35 AM
Evil Elsie's Avatar
Ignition Coil - DBC 1140 = Lucas BR 0849 (land rover part # RTC 5628)
  • BOSCH: 0-221-122-392
  • FUELPARTS: CU1108, 11410
  • MOTAQUIP: LVCL402
  • NGK: 48339
  • QUINTON HAZELL: XIC8048
  • TRISCAN: 8860 15029
  • VALEO: 245120
TheWarlock
Apr 24, 2016 08:37 AM
Woznaldo
Aug 26, 2015 03:45 AM
Mkii250
Aug 14, 2014 04:34 PM
evo mrt
Jan 15, 2012 04:43 PM
