XJ40 ( XJ81 ) 1986 - 1994
Door lock problems
Old Feb 1, 2009 | 02:50 PM
ArmyJag's Avatar
Default Door lock problems
So here is the problem with the 89 XJ6.
1. I can lock the drivers door only with the key in that lock. Does not lock any other door. It will not unlock the door however.
2. Passenger side the key won't do anything I'm assuming that handle has been changed out and the lock cylinder was not. Door locks and unlocks but does not open from the outside, I'm ordering a replacement handle for that one. I'm also going to see if I can have the cylinder re-keyed to match the other door.
3. The power lock button does nothing. I have found no blown fuses in any of the 3 fuse boxes.
So where do I need to start trouble shooting?
Old Feb 1, 2009 | 03:01 PM
JagtechOhio's Avatar
Default RE: Door lock problems
1) Wrong key for a handle which has previously been replaced. Wrong keys will often enable the lock barrel to be rotated to the lock position, but not unlock
2) wrong key for a handle which has previously been replaced, and now requires a subsequent replacement
3) Roll all the windows down, unlock all the doors manually by pulling the pins, push all the pins down, and see it they now operate when you pull up a front door pin. When they lose synchonization, i.e. when one lock actuator motor has failed or the lockplate is sticking, the system disables and you lose automatic function. If you synchronize them all as described, and you may have to walk the walk once or twice, you can then identify the lock which is causing the problem and go from there. It is not a simple system, but the door lock modules almost never fail. The problems are always inside the doors, which means 4 X 5 = 20 places to look for the failure.
Old Feb 1, 2009 | 04:15 PM
ArmyJag's Avatar
Don't want to sound like a dummy here but oh'well lol.
If the key works in the ignition and enough to lock the drivers door and will turn to the unlock just nothing happens is it still possibly the wrong key for the lock?
The steps to syncro the door locks is great, jags are even weirder than Land Rovers lol, I'll give that a try shortly and post the results.
Old Feb 1, 2009 | 04:19 PM
Hold it up to the screen and I'll take a look.
How'd you make out with those blower motors?
Old Feb 1, 2009 | 04:30 PM
ArmyJag's Avatar
haha
So far so good the one surges a bit though. It's odd, at idle say at a light the fan will surge up to a much higher speed and than slow back down when I take off. So that will probably need replaced, I only ended up buying the drivers side as I was able to get the other one working with cleaning the armature and replacing the brushes and springs. Looks like it wasn't a perfect repair though. So I'll have to break down and get a replacement for that one as well( passenger side).
Old Feb 1, 2009 | 04:40 PM
OK, well since you had the rightblower out, then you disconnected the door lock control module in the process. Best have a look at your work there,if the door lock synchronization has no effect.
I bought two blower motors from an independant Jag shop in Marylandon eBay, maybe two years ago. Neither worked, one was a bad transistor plate and one was a worn out armature and brushes. Most of the used ones you will find are untested and likely bad, that's why you can buy them cheap. Good used partsa little different.
Old Feb 1, 2009 | 04:46 PM
ArmyJag's Avatar
The one I bought runs like a champ, it's the one I "repaired" that runs a bit off.
The locks didn't work before I went mucking about but everything is still exposed under there as I haven't put the dash completely back together yet... Alright time to go see what happens with the syncro
Old Feb 1, 2009 | 04:58 PM
ArmyJag's Avatar
So I rolled all the windows down then hit the lock button and held it down while it rolled all the windows up( that's a cool feature). I heard the module click in the dash but no doors locked at all. I hit it a few more times and could hear a click in the passenger side dash, and it sounded like a few others in the car but no locks budged. I'll try lubing the lock plates that I found in another thread and see what happens.
With the key off nothing happened at all though.
Old Feb 1, 2009 | 05:49 PM
Apparently you've been overpaying for all of my free advice. I'll let others set me straight, I'm sure you'll get help with that.
Old Feb 1, 2009 | 07:36 PM
ArmyJag's Avatar
no your advice has been great, it's a lot more than I had to start with. It's appreciated brother
Old Feb 3, 2009 | 05:13 PM
ArmyJag's Avatar
I double checked everything under the dash with the lock module and it's all hooked up and I can hear it click when the key is on and the button is pressed....
I did however figure out that it does lock the boot.
99xk8guy
Sep 29, 2025 10:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
