XJ40 ( XJ81 ) 1986 - 1994
Door locks
Old Apr 24, 2011 | 09:22 PM
Buegs's Avatar
Default Door locks
I have an 88 XJ6 that has suddenly developed a problem with the rear door locks. When I insert and turn the key to unlock the doors the rear locks pop up but immediatly pop back down. This also accurs using the button on the dash. I understand theres a couple of different sources, I guess I'm looking for the most common. Thanks
Old Apr 25, 2011 | 07:31 AM
motorcarman's Avatar
You need to lube the latches. The actuators can only apply so much force and sometimes that is not enough to overcome neglected latches.
Most of the time lubricating works but sometimes they need replacement if severely corroded or damaged/broken.
bob gauff
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrsimpson
Sep 15, 2015 01:10 PM
