XJ40 ( XJ81 ) 1986 - 1994
Greasing the u-joints
Old Aug 11, 2016 | 07:58 PM
Lawrence's Avatar
Default Greasing the u-joints
Plan for the next job is to replace any missing zip-ties under the rear of the car and to grease the output shaft u-joints ...
What type/grade of grease would you guys suggest I buy?
TIA
Larry
Old Aug 11, 2016 | 10:52 PM
Doug's Avatar
I use that red synthetic wheel bearing grease for u-joints. And wheel bearings. And ball joints, ties rods, whatever. Any name brand is OK.
Old Aug 12, 2016 | 09:47 AM
Don B's Avatar
Larry,
When I last did the front & rear wheel bearings and diff rebuild on our '93 I read the labels of all the greases carried by our local O'Reilly and opted for the Lucas X-TRA Heavy Duty Grease, which had the highest liquefaction rating (560F). I used it in the wheel bearings, U-joints, hub carrier bearings, etc.
I think Doug is right - any brand rated for wheel bearings should be fine in the U-joints - the important thing is to keep forcing new grease in until all the old grease has come out. The hardest U-joints to do are the ones in the rear hubs - you have to get them turned just right to access the nipple. Much easier with the hub removed. You don't need to do your rear wheel bearings, do you?
Cheers,
Don
Old Aug 12, 2016 | 10:20 AM
Lawrence's Avatar
Oh probably ....the list never seems to get any shorter
Larry
Old Aug 16, 2016 | 12:55 AM
Lawrence's Avatar
But ...I found it pretty straightforward after all!
Although there's only a small open "access window" when the wheels are in the correct position, it was pretty easy to locate the sweet spot with the trans in neutral ...so all done easy peasy.
cheers
Larry
philwarner
17
Apr 30, 2016 07:08 PM
NCJagman
Apr 15, 2016 12:40 AM
XJ40 ( XJ81 )
Apr 13, 2007 08:24 PM
Feb 25, 2007 05:26 AM
