XJ40 ( XJ81 ) 1986 - 1994
help needed with xj40 boot
Old Nov 15, 2010 | 12:43 PM
bux186's Avatar
Default help needed with xj40 boot
I have a 1988 xj40 and the boot no longer opens i think that something has broken inside, the lock turns with the key but the release button is solid also the central locking no longer works so the release button wont do anything.
i know that you can drill a hole on the x300 to release the boot but not sure if that would work with the xj40 the only thing i can think of is to take the back seats out so any input would be appreciated.
thanks
Old Nov 15, 2010 | 01:04 PM
Removing the rear seats won't help you, there is a solid steel bulkhead behind them, to protect you from the fuel tank.
I believe that the hole idea is also the same here. (You are using the Black master key, yes)?
Old Nov 15, 2010 | 02:51 PM
ken@britishparts.com's Avatar
Remove the number plate. With a long screw driver you can trip the lock. It's not an easy procedure. Plan on lots of cussing and swearing. You almost need to bend the screw driver back towards the number plate to catch the lock. It's no fun.
Old Nov 15, 2010 | 09:23 PM
motorcarman's Avatar
Ken is correct
The number plate mount cutouts in the boot lid here in the states are plenty big enough for reaching into the mechanism rods to release the latch. I imagine that they are similar in Europe. Unless you do this regularly, I always liked having another car in the shop to pull the carpet liner to see exactly where the components are located but poking and pulling seems to work after a while. The rod needs to be pulled UP to release the latch.
bob gauff
Old Nov 16, 2010 | 03:55 AM
bux186's Avatar
Thanks for the info i had an idea the bulkhead would be solid and confirming this saves alot of time and have tried the master key with no joy.
i will remove the number plate and give the screw driver a go and let you know
thanks guys
Old Nov 20, 2010 | 04:40 AM
I wonder if the boot shut on him?
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
XJsc-guy
Sep 2, 2015 11:43 AM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
