XJ40 ( XJ81 ) 1986 - 1994
I love my Jag, but...
Old Jun 22, 2008 | 01:26 PM
Cadillac's Avatar
Default RE: I love my Jag, but...
Welcome to the forums
You should also replace the fuel filter . I believe our tech guys know better for sure
Old Jun 23, 2008 | 02:45 PM
ken@britishparts.com's Avatar
Still wide open on this one. Could be 02, air flow meter, stepper motor, clean out throttle body, crank position sensor, etc.
Old Jun 26, 2008 | 11:13 AM
Add to your list of normal maintance to clean the crank position sensor. It's at the front of the timing coving at the harmonic balancer. It easily picks up road dirt and doesn't read correctly. Just wipe it down. No big deal. Probably don't even need to remove it. Just get a rag in around the head.
Old Jun 26, 2008 | 09:58 PM
Bnc2doz's Avatar
Funny... my Jag was doing the exact same 'hesitation' thing as yours was. I didn't drive it as much for a while, and it gradually went away.
Old Jun 27, 2008 | 11:12 AM
93xj6's Avatar
Mine did that in the winter a lot. I got new fuel injectors put in, and that's when it started doing that. I just stopped driving it for a while because I was scared, and than it hasn't done it to much since. I think it was mainly caused by the cold weather, cuz this was around when it was -5 degrees average in Chicago for a good month.
Old Jun 27, 2008 | 07:58 PM
XJ40ish's Avatar
Do yourself a favor and save a lot of money. Go to your dealer and have the car scanned for codes. This will pinpoint any faulty sensors and you might be suprized which one is causing you grief. Mine was stalling and had an intermittentcheck engine light which when it came on had the catrunning like crap. Truns out to be a faultycoolant temp sensor causing all the rest to act oddly. If you want to keep a Jag you need deep pockets and remember for your overall investment they're terrible to resell or get any money back. Drive it, love it, then dump it. Do not put a lot of your hard earned money into it. All that said, you'll get a lot of advice when you have a Jag... some even usefull. But trust me on this before you get too far intoit. Go to the dealer and have it scanned. It will cost you an hours labor charge and is well worth it.I replaced a lot of good parts for no reason on the advice of other usually starting with "Well...90% of the time it's..." I've found 100% of the time they've been wrong.
Forcedair1
Sep 8, 2025 01:57 PM
allenman85
May 10, 2021 03:11 PM
john_cook12
Sep 9, 2015 03:47 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
innzane
Sep 2, 2015 10:08 AM
