XJ40 ( XJ81 ) 1986 - 1994
Installing door seal
Old Mar 23, 2014 | 07:51 PM
mickvic's Avatar
Default Installing door seal
Hi got new rubber doors seals (made in thailand $65 each)the old ones easy to pull out but the new ones....well quite tricky to put in if nigh on impossible for me. Does anyone know any tricks to getting these in or any good tools?? Mick 91 kingfisher blue xj40 melbourne aust.
p.s. interesting the seal installation is exactly the same as my 73 xj6 series one jag liked to stick with the old ways.
Old Mar 24, 2014 | 12:13 AM
Lawrence's Avatar
I just installed a new front door seal on my '94 XJ40, it was aftermarket also, brand was URO. I used copious amounts of liquid hand soap in the channel and the seal installed fairly easily with basically thumb pressure and the odd prod with a blunt screwdriver - however I've heard from others that the rear seals are not so easy - in fact downright difficult.
Good luck with yours!
Larry
Old Mar 24, 2014 | 06:34 PM
Don B's Avatar
Hi Mick,
We're all jealous of how easily Larry installed his new door seals with just thumb pressure!
Below is a link to photos of how I did the job. I didn't find the rear seals any more difficult than the fronts, but a fellow member of the Jag-Lovers XJ40 forum had a terrible time, and finally realized that the rear seals he received were significantly fatter than the fronts, with a larger bead that just didn't want to fit into the channel.
Let us know how it goes.
Cheers,
Don
Welcome to Jag-lovers - Members Photo Viewing Page
Old Mar 24, 2014 | 09:00 PM
Superb Don B....thank you
Old Mar 25, 2014 | 06:15 AM
mickvic's Avatar
Thanks Don. Love that magnetic strip. Never seen that before !
Old Mar 26, 2014 | 04:48 AM
mickvic's Avatar
well got one on...less rubber than I though quite tight in places, and a heap of effort required. The soap is the saviour thanks for the tip.
Old Mar 26, 2014 | 11:08 AM
Don B's Avatar
Congratulations! Now that you've done one, the next one(s) will be easier.
Cheers,
Don
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
d a
Sep 3, 2015 02:34 AM
