XJ40 ( XJ81 ) 1986 - 1994
Jaguar Acronyms, Abbreviations, Terms & OEMs
Old Feb 14, 2015 | 04:49 PM
Don B's Avatar
Top Answer: 5
Default Jaguar Acronyms, Abbreviations, Terms & OEMs
Fellow members,
Over the years I have kept lists of Jaguar acronymns, abbreviations and terms, as well as Original Equipment Manufacturers. I recently added information from current Jaguar models and have posted the lists in the General Tech area. If you find time to review the lists, I'd be grateful if you can offer any additions or corrections to make these as complete and accurate as possible
Jaguar Acronyms, Abbreviations & Terms:
https://www.jaguarforums.com/forum/g...9/#post1161835
Jaguar Original Equipment Manufacturers (OEM):
https://www.jaguarforums.com/forum/g...rs-oem-136806/
Cheers,
Don
Old Feb 14, 2015 | 06:34 PM
Lawrence's Avatar
very quick perusal Don, I noticed A. Raymond Tinnerman listed twice and you could probably add a/c equipment (condensers) to the Hella listing ..
possible to make scroll list a bit wider?
cheers
Larry
Old Feb 14, 2015 | 08:48 PM
Don B's Avatar
Top Answer: 5
Hi Larry,
Several listings are duplicated if there are more than one logical way to alphabetize them (A Raymond, Raymond A) to help readers find them more easily depending on their own sense of how they should be alphabetized. I know it increases the length of the list, but hopefully with the benefit of increased usefulness.
Thanks for the tip on Hella condensers.
Graham (GGG) is trying to help devise a better way to present the list - I've just used a simple CODE tag which has no flexibility on width. Hopefully Graham will figure out a better format.
Thanks again!
Cheers,
Don
Old Feb 14, 2015 | 10:16 PM
Lawrence's Avatar
Don, I realise the list may alphabetise differently - however the listing that duplicates tinnerman (at the bottom of the list, under Raymond A) is identical and just 2 lines apart - don't mean to be a nitpicker but I'm sure you'd like to fix that.
cheers mate
Larry
Old Feb 14, 2015 | 10:33 PM
Don B's Avatar
Top Answer: 5
Ah! Found it. RB&W was also duplicated. Thanks Larry! Care to proofread both entire lists for me? You've got a good eye!
Cheers,
Don
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
TC Johnson
Sep 2, 2015 09:30 AM
