XJ40 ( XJ81 ) 1986 - 1994
Longevity of front shocks
Old Feb 13, 2019 | 02:27 PM
Ernest Knox's Avatar
Default Longevity of front shocks
My 1988 Vanden Plas is making a metal on metal sound whenever the drivers side wheel hits a hole in the road. I've checked the wheel, rotar, brakes, and control arm, and believe the noise is from the shock absorber. There is no noticeable bouncing on the front end, but the shocks have 50K miles on them. Some are saying never replace shocks unless there is an issue. I can't believe shocks last for ever. These are Bilstein. Could it be more likely the bushing and not the shock?
Old Feb 13, 2019 | 03:06 PM
Lawrence's Avatar
Usually and almost always the upper bushings. Easy job to replace, they are a common maintenance item on the XJ40
Larry
Old Feb 13, 2019 | 03:22 PM
Thanks.
Old Feb 13, 2019 | 03:46 PM
Lawrence,
You are correct. I just examined the top portion of the shock in question, and the bushing has disintegrated. Easy repair.
Old Feb 13, 2019 | 05:02 PM
jerry_hoback's Avatar
Yay!!! An easy fix!!!!
Miss J
Oct 4, 2010 02:17 PM
mmolaik
Sep 21, 2010 02:44 AM
JJ's Jags
Jul 24, 2010 04:20 PM
jkviper
Dec 2, 2008 12:49 PM
preacher
Dec 19, 2007 04:31 PM
