XJ40 ( XJ81 ) 1986 - 1994
Making progress
Old Aug 16, 2020 | 07:17 PM
Snoopy69's Avatar
Default Making progress
Hello All,
Well after 6 months and 3000 dollars, my 1993 XJ12 is back home!
Here are some things I had repaired:
Brakes are fixed
The oil cooling hoses are rebuilt and replaced
The coolant tank has been replaced
All the leaks are repaired
Both high pressure and low pressure fuel pumps are now operational
Front end alignment was completed
All the tie rod ends are replaced
The car runs down the road now without fear of it dying.......what a fun car to drive!
Now I must save up some more so I can put new tires, new fuel sending unit, a new windshield and a paint job on this machine.
We are progressing........
Some questions,
1) When I got it home there was a cooling fan that continued to run after I shut the car off for a bit then it shut off. Is this normal?
Anyone with insight, please advise.
Thank you all,
Eric Schutte
Old Aug 16, 2020 | 09:35 PM
Lawrence's Avatar
Perfectly normal - mine run for a minute or two after shutdown on a warm day. No need to worry.
larry
Old Aug 17, 2020 | 07:48 AM
jerry_hoback's Avatar
My 94 fan runs after shut off but only a few seconds.
Old Aug 17, 2020 | 09:17 PM
Don B's Avatar
Hi Eric,
All of your achievements are notable, but the one that really makes me applaud is that all the leaks are repaired!
Truly, that is a major accomplishment!
Congratulations!
Don
darrellleece
Aug 16, 2017 07:22 AM
kesslari
Nov 7, 2016 02:00 PM
NorCalDiesel
Sep 6, 2012 07:06 PM
randyb
May 13, 2012 07:05 AM
