XJ40 ( XJ81 ) 1986 - 1994
to motorcarman
Old Oct 19, 2011 | 08:10 AM
Lumppy47's Avatar
Default to motorcarman
Thanks for your reply,My problem is wher can i get some main bolts(have tried every company and dealers and no one has or can order these) do you know of any one who has some. For a 1990 xj6.Thanks again
Old Oct 19, 2011 | 08:25 AM
motorcarman's Avatar
I called the Dealer I used to work for and the EAC4119 is NLA.
You might try Motorcars LTD in Houston and see if they have an old block to get the once used bolts and re-use them!!
You might have to buy a used/damaged engine and steal the bolts from it.
Try ARP and see if they have a substitute or UPGRADE stud/nut kit.
bob gauff
Old Oct 19, 2011 | 08:41 AM
Lumppy47's Avatar
Old Oct 19, 2011 | 03:23 PM
Thermo's Avatar
Veteran: Navy
Lumpy, if you know the thread size, then you can probably get what you need through a place like Fastenal. They will get just about any bolt you need, in the length and strength rating you need. All the information that a place like that would need is written right on the bolt itself believe it or not. So, may want to take a bolt in and see what they tell you.
Old Oct 19, 2011 | 08:47 PM
Lumppy47's Avatar
Thanks for the replys,tried the fasinal store here and the help were no help at all.Then got in touch with ARP and they had some that will work(fyi the length is 90mm thread size is12mm with a 1.75 pitch and they are available with either socket(allen head) or regular 6 corner heads.
Markus
Sep 28, 2015 01:55 PM
edtexas
Sep 5, 2015 10:49 AM
aholbro1
Sep 22, 2014 03:46 PM
mjlaris
May 8, 2014 07:19 PM
Sentinelist
Mar 17, 2014 11:55 PM
