XJ40 ( XJ81 ) 1986 - 1994
No lights on warning or turn signal sound?
Old Apr 13, 2021 | 02:29 PM
Simon Johansson's Avatar
Default No lights on warning or turn signal sound?
Had this problem on my xj40 1989 since I got it, got so used to it but would like to have it fixed, i have no sound to indicate that I'm having my turn signal on except the arrow in the dash, and when I leave my lights on i have no kind of warning for that either?
If i have my car in gear while I turn it of it's a loud buzz from under the steering column so the speaker there works...?
What could this be? I have looked around so much I can but don't really know what to check.
Best regards!
Old Apr 15, 2021 | 02:17 AM
Sovejag13190's Avatar
Hi have you sound when you move the selector gearbox out of "P" ? For light on my 87 there is not sound for light, i modified my system to have it.
Old Apr 15, 2021 | 02:24 AM
Originally Posted by Sovejag13190
Hi i've you sound when you move the selector gearbox out of "P" ? For light on my 87 there is not sound for light, i modified my system to have it.
Yes when I move it out of "P" it sounds, but now when turning.
Oh okey, how did you modify that? Maybe it doesn't have the warning for lights on by default?
Old Apr 15, 2021 | 02:38 AM
I've modified wiring under steering wheel. I use relay. Relay is on with contact and light and off whithout contact. On the contact i use sound wire.
Old Apr 16, 2021 | 09:09 AM
Don B's Avatar
Hi Simon,
The lights on warning sound emits from the Lights On Warning Module, a small audio annunciator shown as Part 12 in the diagram below. The turn signal sound emits from a small 2-inch/50mm speaker which is soldered to the harness for the Cancellation Module, Part 3:
The speaker has an unusually high impedance rating (I seem to recall that it is 60 ohms impedance, and one of our members measured a DC resistance of around 54 ohms). When ours failed, I replaced it with a standard 16-ohm speaker and it worked, but the output volume was low.
You can view the diagram above and the associated part numbers at the link below. If I guessed the wrong VIN range, just go to the VIN range that suits your car:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Cheers,
Don
Old Apr 16, 2021 | 09:16 AM
Yes but the sound to gearbox position level it's the same speaker no? And the gear position out of "P" it's OK
Sentinelist
Jul 5, 2013 09:54 AM
Stillill
Feb 4, 2013 11:31 AM
kvmentor
Jan 8, 2012 07:41 PM
ExKay8
May 14, 2011 07:49 AM
