XJ40 ( XJ81 ) 1986 - 1994
no power windows or locks
Old Dec 12, 2010 | 03:34 PM
jsmolin's Avatar
Default no power windows or locks
i really need some help here please! none of my power windows work not from there inividual switches or the drivers side switch, my power door locks also do not work from the console door lock switch or with the key. i have checked all my fuses in the car and all is good. i was going to check for relays but i am under the impression each window switch has a relay built into it i am new to jags and this is my first one it is a 1992 xj6 van deplas with 180,000 miles on it. it runs great and i only paid $800 i hope i wont be sorry
Old Dec 13, 2010 | 02:03 PM
mrtalkradio's Avatar
You'll get it. First thing is patience, I know this is the instant communication era but here on the forum it takes a little time. I get anxious as well. The forum has helped me to slow down. When you get suggestions, try and follow them. First use the search feature here and use key words that describe your issue, you can just about bet that someone else has gone through the same thing you are. Also you need a haynes manual for that car so that you can see where all the relays are. Your issue is electrical and can be fixed just know that. Keep on Keeping on!
Old Dec 13, 2010 | 04:11 PM
jsmolin's Avatar
Default door locks
thank you first of all and youre correct i need to be patient i spent sometime on the car today and found the problem with the locks there was a broken wire to the door lock module but i still cannot figure out why not one window works i checked all the fuses and there good, i checked the body ecu no probs does the master switch whis is melted control all the windows the funny thing is the power mirrors work thanks again jon
Old Dec 14, 2010 | 01:07 AM
I'm pretty much stabbing in the dark, and really just giving you guys a little moral support.
Have you tried moving the small switch in the middle of the driver's master door window switch block.
It is tiny, but it serves to isolate and prevent other windows from being operated from their individual door switches. At least on my 92 it does.
Also, when you lock the driver's door with the black master key, try holding the key in the locked position for a few seconds. If a window was open (I know they are not) this action would close the windows. Dunno, might help reset something.
Did you mend the broken wire? because the lock module seems to also action the window closing.
Hopefully someone with a bit more savy can chime in.
Old Dec 14, 2010 | 05:56 AM
jsmolin's Avatar
i did mend the wires i got the power locks to work as they should but still no wondows but thank you for youre input jon
Old Dec 14, 2010 | 06:00 AM
jsmolin's Avatar
Default publication s-91
to the moderator can you get me permission to download publication s-91 and the directions on how to get the download thanks jon
Old Dec 14, 2010 | 06:35 AM
@jon, I have checked your profile, you have already got full access to the forum so you should have no problems.
Where have you seen "publication s-91" because I'm pretty sure that I have not added it to the TSBs? If you can point the way I'll see what can be done.
Old Dec 14, 2010 | 08:18 AM
motorcarman's Avatar
Translator
I uploaded it to the mediafire site a few weeks ago
bob gauff
Old Dec 14, 2010 | 11:58 AM
jsmolin's Avatar
bob can you please direct me on where to look so i can download the bulliten thanks again jon
Old Dec 14, 2010 | 01:04 PM
I think this is what you are after Jon.
publication s 91
@Bob, cheers mate looks like you have been busy out there. I need to spend some time going through and adding to the FAQs / TSBs. To host here if we can.
Keep me out of mischief for a while. LOL
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
1964Daimler
Sep 9, 2015 11:28 AM
