XJ40 ( XJ81 ) 1986 - 1994
No start after long storage - bad gas?
Old Apr 27, 2011 | 01:11 PM
outsidenote's Avatar
Default No start after long storage - bad gas?
My 1991 X6 has been on blocks for several years due to a blown head gasket. I replaced the head gasket and now it won't start. Brand new battery, turns over, fuel pump comes on but wont fire. At first I realized I stupidly forgot to attach the high tension wire to the distributor but now everything checks out. Compression is good. The tank is full but the gas is years old. Can the gas go bad? I will try to see if it will fire with ether. If so I probably need to drain the gas tank. Any other ideas?
Old Apr 27, 2011 | 03:45 PM
Trick Freestones's Avatar
Smile
Hello outsidenote,
I looked for your introduction, but didn't find one. I realize you want to get your Cat up and running as quickly as possible but you need to write one.
Sure, gas can go bad after sitting for long periods without some kind of stabilizer in it -- it can also plug up carburetor orifices just by sitting in the float bowl.
Looking forward to reading your intro.
Old Apr 28, 2011 | 11:27 AM
Hi o,
Have you figured out whether it's a fuel or fire problem?
You may want to read Rex's thread,
88 Vanden Plas still won't start
for quite a few ideas to follow.
If you please, keep us informed of your progress.
PMKimpton
Aug 3, 2019 08:22 PM
Charlene n John
Sep 28, 2015 06:01 AM
alpecsa
Sep 7, 2015 11:55 AM
Charlene n John
Sep 6, 2015 11:03 AM
XFR_Gold
Sep 2, 2015 12:24 PM
