Just purchased a Beautiful xj6 1991 with 57k. One of the small problems is noisy lifter! Was told that they arehydraulic and cannot be adjusted. Then told mechanic after he recommended an oil aditive that I had synthetic oil - he said that was not good and may well be reason. Told me to go to normal oil 20-50 and add the pint of the additive.
Opinions on that?
ALSO how is door seal installed? Glued ? or . I need to R/R mine, already have new sills on the way.
Thank you
Opinions on that?
Thank you
Cadillac
close
- Join DateMar 2007
- LocationPlanetarium
Liked:649 Times in 448 Posts
If you fully use sytn oil you would not need any oil additive . I have been using Castrol Edge 10W60 due to my Jag Specialist's highly recommendation .Otherwise I would go for 20W50 as well
The lifters are not hydraulic. They are solid lifters and can be adjusted with shims. It's a real pain in the ***. The door seal is not glued in but you will learn a few new curse words on the install.
Quote:
Thank you but if nor glued in how do you go about changing them (after removing sill plate) Thanks.Originally Posted by ken@britishparts.com
Fraser Mitchell
close
- Join DateDec 2009
- LocationCrewe, England
Liked:2,548 Times in 2,021 Posts
When you have the new seal, look at the section, and you will see it is moulded so as to fit into a channel. It is getting it into this channel that puts the anguish into being a DIT Jag owner. Factory fitters have access to special trimming tools to do these jobs.
Fraser Mitchell
close
- Join DateDec 2009
And more.......
Noisy lifter could be a valve sticking, so tread carefully. How long since car last ran with the previous owner ? Suggest you at least check all the clearances by taking cam cover off and using feeler gauges.
Car was being driven regularly by last owner. Has 57K miles on it.Originally Posted by Fraser Mitchell
And more.......Noisy lifter could be a valve sticking, so tread carefully. How long since car last ran with the previous owner ? Suggest you at least check all the clearances by taking cam cover off and using feeler gauges.
Does have synthetic oil.
Ordered cam cover gasket because I was going to "adjust" lifters bUT now I know I cannot! Was quoted $ 1,100.00 by Jag dealer to do job? Fair price?
TY
