XJ40 ( XJ81 ) 1986 - 1994
Odd issue
Old Mar 1, 2012 | 10:44 PM
Hobart_XJ40's Avatar
Default Odd issue
Hi All
had an odd issue yesterday - I had been out and returned home for about 30 mins when I had to go out again... try to start the car, and no go, volt meter in the red...
I got a reading of ~ 12.5v from the battery, in the mean time, due to where I had parked, I though I would roll the car backwards a little so the roadside assistance could get better access to the engine bay
I straightend the wheels, took the HB off and the GB in N (while my neighbour stopped it rolling forward... went round to push, but it was too heavy to move as it was on a slight downhill angle.
Got back in to out it in P and put the HB on when I thought I would try starting it again, turned the key and away she went, first crank
Hasnt missed a beat since, so im thinking maybe something loose around the starter maybe? - has anyone come across this before?
Old Mar 3, 2012 | 01:55 AM
mrtalkradio's Avatar
The transmission switch and or linkage is the issue. If the car doesn't know it is in Park for sure, it won't start.
Old Mar 27, 2012 | 06:36 PM
jc1kz's Avatar
I have this problem on occasion, the not starting, but I can always tell if the shifter is not in proper park position because when the key is in the ignition, the car makes a loud ding, ding, ding, sound, and then I just wiggle the shifter a bit and the dinging stops and the car starts....
(note to self, need to replace the shift - "thing-a-ma-jig" soon, after replacing the "low brake presure")
back to topic what "mrtalkradio" said it is the shifter being a bit loose and not signaling it is in Park.
Just my two cents.......
Old Mar 27, 2012 | 08:56 PM
limegreenclown's Avatar
mine has only started in N for the last 2 years, I think its a common failure
Scarecrow
Mar 28, 2016 03:17 AM
tberg
Sep 17, 2015 10:43 PM
Wolfy
Sep 10, 2015 09:50 AM
carelm
Sep 5, 2015 01:13 AM
