XJ40 ( XJ81 ) 1986 - 1994
Oil cooler bypass
Old Jan 31, 2013 | 10:39 PM
Robert's Avatar
Default Oil cooler bypass
The oil cooler lines on my 1990 XJ6 were leaking badly, so I've purchased an oil manifold from PartsBin. Removal of the oil cooler lines has been easy, and installing the manifold was no problem...except that the stud is not long enough for the original lock nut. Would a thinner plain nut and some Loctite be okay?
Old Feb 1, 2013 | 04:37 AM
I cannot see why not.
Did you get the 2 sleeves that fit between that manifold and the oil filter housing when you got the manifold????.
It will be a mongrel to seal without those sleeves and the 4 o/rings.
Old Feb 1, 2013 | 08:10 AM
Robert's Avatar
Yes, I received the manifold, two connector tubes, and four O-rings. The manifold fits flush against the manifold so it's not like it isn't seated. After install, there's about 1/4-inch (don't know what that is in metric) of threads showing.
Old Feb 1, 2013 | 11:03 AM
xjrguy's Avatar
Two options:
Replace the stud with the longer one.
Remove the stud and use a bolt of the appropriate length.
Cheers,
mrplow58
Jan 21, 2024 05:53 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
twinstacks
Sep 19, 2015 01:09 PM
Tim Goz
Sep 17, 2015 09:11 AM
Busa R
Sep 10, 2015 07:28 PM
