XJ40 ( XJ81 ) 1986 - 1994
Oil pressure fluctuations
Old Feb 24, 2018 | 01:54 PM
OrigamiSensei's Avatar
Default Oil pressure fluctuations
Hi folks, 1988 XJ40 with the 3.6 here. When sitting in traffic, particularly pointed downhill I will see the oil pressure gauge drop down to zero at times, which is pretty frightening. Then when I get moving the oil pressure will bounce right back up where it belongs. Oil level is good, just had the oil changed and I just checked the level again.
Sensor problems, natural fluctuations, oil starvation to the sensor when sitting, any ideas what is going on? I really don't like seeing my oil pressure drop since I don't need a blown engine.
Old Feb 24, 2018 | 03:04 PM
Lawrence's Avatar
No need to worry, this is a well known issue with the sender unit ..your oil pressure is probably just fine.
This thread has all the information you need to fix it:
https://www.jaguarforums.com/forum/x...sender-133621/
Larry
Old Feb 24, 2018 | 04:07 PM
That is super helpful, and I guess it will be my next project. I actually don't mind working on these sorts of things as long as the car runs okay. It is thirty years old, after all.
Old Feb 24, 2018 | 09:23 PM
Lawrence's Avatar
I think we've all had the oil pressure "jitters" at one time or another ..those old senders can frighten the most dedicated of us!
Good luck
Larry
Qvhk
Jan 1, 2018 10:10 AM
nilanium
Jan 26, 2017 06:17 PM
TinyDancer91991
General Tech Help
Jul 26, 2013 06:58 AM
Ish
General Tech Help
Jun 12, 2013 04:03 PM
Skid Mark
Feb 5, 2013 10:22 PM
