XJ40 ( XJ81 ) 1986 - 1994
Park/Neutral Shifter Problem
Old Apr 1, 2012 | 10:37 PM
Palmero's Avatar
Default Park/Neutral Shifter Problem
1992 Jaguar Vanden Plas.
Engine won't crank with shifter in Park. If I move it slightly, then it cranks. Neutral works fine.
Does anyone have experience with adjusting the start prevention switch? Is this an under-the car (transmission) adjustment, or at the shifter?
Thanks.
Old Apr 2, 2012 | 05:25 AM
It is inside the car.
Remove the console top slope thingy, and on the R/H side of the shifter mechanism is a switch pack, and that is the sucker you have to deal with. I would remove it, 2 screws, a tad fiddly, and give it a good clean with contact clean, then refit and reset so as it does what it should before putting the timber back.
They can fail, but that is quite rare, as a good clean has always got them working again for me. Just did the X300 (same) and although it was working fine, the amount of crud I flushed out of it was scary.
Old Apr 3, 2012 | 10:21 AM
Palmero's Avatar
Will give that a try. Thanks!
neruda
Oct 18, 2015 01:19 PM
Phil G.
Sep 12, 2015 07:42 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
