XJ40 ( XJ81 ) 1986 - 1994
Part Needed
Old Oct 26, 2010 | 03:01 PM
mrtalkradio's Avatar
Default Part Needed
This little rubber hose is a connector is attached to the purge valve. Problem is, is that it is one of a kind, larger on one end and smaller on the other, I don't think it even has a name. Anyone know the name and where I can get it? Second part is, was this purge valve on cars 89-94?
Old Oct 27, 2010 | 12:30 PM
retromotors's Avatar
Here's a breakdown on that system. It looks like you need #7 ... "reducing hose".
At least that will give you a description and part number to work with.
http://www.jaguarclassicparts.com/ht...cationType=JCP
Good luck!
EDIT:
Aw rats ... I just discovered the link won't take you to the exact page.
You'll have to start from there and work your way through the maze to find it!
Old Oct 27, 2010 | 12:51 PM
Hey Retro nice link, but can you, edit so that it leads directly to the parts being talked about, rather than the site home page.
Cheers,
Richard
Old Oct 27, 2010 | 03:43 PM
ken@britishparts.com's Avatar
Looks like you will have to order from Jaguar. Good news is they are not expensive, less than $5. Part number is EBC10152
Old Oct 27, 2010 | 03:56 PM
Cheers,
Richard
I thought that's what I was doing, but apparently something about the way that site is set up, it just doesn't work that way. Hence the edit at the bottom of my original post.
Here's the path to follow through the maze:
XJ6 & XJ12 (XJ40)
XJ6 (2.9, 3.2, 3.6, 4.0) From yada yada yada
Engine Management/Emission System
Evaporative Emission Control System
Carbon Canister Purge Control
Stigram
Jun 17, 2022 12:05 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
MarathonJohn
Sep 3, 2015 07:59 PM
1964Daimler
Aug 31, 2015 06:41 AM
divingmom
Aug 25, 2015 07:54 PM
