XJ40 ( XJ81 ) 1986 - 1994
Rear ABS sensor and transmission 1990 XJ6 base model
Old Nov 10, 2013 | 09:41 AM
mark479's Avatar
Default Rear ABS sensor and transmission 1990 XJ6 base model
1990 XJ6 base model. I had a rear axle assembly replaced that had a bad ABS sensor. Of course the ABS light is on, but a week later I have a transmission light on some days, and then off some days. Is the ABS sensor necessary for the transmission to work properly?
Running wise it seems to be working fine. When I got home I checked the oil when the transmission light was on, and there was no oil on the dipstick. So I got the oil out of the trunk, turned on the car, checked the oil level again before I added any oil, and the oil level was fine.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
GuernseyJag
Nov 8, 2017 10:40 AM
dpappyp
Aug 27, 2015 06:31 AM
NinoGrimace
Aug 26, 2015 05:15 AM
