XJ40 ( XJ81 ) 1986 - 1994
rear shockies
Old Dec 4, 2013 | 03:58 PM
Moodieblue's Avatar
Default rear shockies
Hi Guys
I am looking for a video that shows the process of removing the rear shockies on a xj40, not the self leveling model. I have seen one on the net but forgot to bookmark it and cant find it in my history as that is cleared frequently. If you have any links I would love to see them. I am getting the rear bushes replaced and I was told that the rear seat must come out to access the top nut, is this correct?
Old Dec 4, 2013 | 07:05 PM
NEO Cat's Avatar
Default Rear Shocks
No ,the rear shocks come out as an assembly with the spring. If you meant the rear seat inside the car- no there is no access inside the car.All the removal is from underneath the car. They are not that difficult to remove but you will need a spring compressor to release the spring once you have the unit out from the car. I'm assuming the older xj40 shocks are similiar to the 94 that I have. If you look on JDHT you will see a breakdown of the rear suspension to give you a better idea of how they are removed.
Old Dec 4, 2013 | 08:28 PM
motorcarman's Avatar
Once they are disconnected from the body and suspension you need to turn them 1/2 turn (on the vertical axis) to clear the caliper.
My personal best time for converting SLS to normal dampers is 45 minutes (BOTH REAR DAMPERS).
I did alot of these back in the 1990s.
bob gauff
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
AtholC
Sep 9, 2015 09:07 PM
timm525
Sep 8, 2015 07:57 PM
