XJ40 ( XJ81 ) 1986 - 1994
Rebuilding early Adwest rack - Problems with pinion
Old May 26, 2023 | 09:24 AM
XJeej's Avatar
Default Rebuilding early Adwest rack - Problems with pinion
Hello all, Im struggling and puzzled by my Adwest rack and rebuild kit. The output seals were majorly leaking but the pinion was fine. Anyway. I'm putting all the seals in and cant seem to fit the pinion seals. They dont seem to fit on due to the geometry of the pinion itself.I think Ive already ruïned 1 ring but I got spares.
If anyone remembers this job and can tell me how they did it? I considered heating the seals up in boiling water but would rather not waste my time or seals.
Then another, I totally messed up taking the rack apart. I didnt check the orientation of some seals. The output seals I fitted with the notched out part pointing inward, I hope this is ok?
Old May 26, 2023 | 03:13 PM
xjack's Avatar
if i remember well it was extremely tight fit, i think i have stretched them carefully before trying to fit over pinion, heating may help a bit and takes only few secs
Old May 27, 2023 | 09:26 AM
XJeej's Avatar
Ive made a makeshift tool to get these seals on and they stretch massively, will this shrink back?
Old May 27, 2023 | 09:38 AM
XJeej's Avatar
I did find a source with good advice https://classicbroncos.com/forums/th...cement.240048/
Lemme try that and Ill report back
Old May 27, 2023 | 12:20 PM
xjack's Avatar
you gonna push it all back into tower so they have no other choice but contract
Old Jun 2, 2023 | 06:45 AM
XJeej's Avatar
This has worked well, in case the link goes dead: Wrap electrical tape around the seals with increasing tightness. A hoseclamp is optional. Overnight the seals contract to their initial size and they fit in the housing.
I've ran the engine and steered and didnt notice any leakage. This is pretty surprising to me as a 1st rebuild.
Old Jun 2, 2023 | 07:26 AM
xjack's Avatar
Good job, one more resurrected rack!!!
knares
Feb 11, 2023 09:26 PM
mansterckp
Sep 2, 2021 11:49 AM
NJ2003XJ8
Jul 21, 2021 08:01 PM
juha.
XJ40 ( XJ81 )
Jun 8, 2017 11:52 AM
White Jaguar
Jun 25, 2013 06:48 AM
