XJ40 ( XJ81 ) 1986 - 1994
recommissioning a/c system
Old Mar 14, 2024 | 06:48 PM
jerry_hoback's Avatar
Default recommissioning a/c system
All Right guys and gals, my turn has come around again.
The A/C system on my 92 has been on sabbatical for several years- I know, bad on me for leaving it go. It died when the compressor guts disintegrated and apparently got sent throughout the system (which I didn't think about in time...) so I bought a used compressor, had the system charged up and it worked for exactly 2 weeks then suddenly stopped cooling at all. i gave up out of frustration. Now I am replacing everything that is available with new except for the evaporator. I have the muffler soaking in metal cleaner/ rust dissolver which claims it can be rinsed away with water. This only leaves cleaning the evaporator effectively without removing it. Does anyone have a flash of brilliance for me as far as either method or chemical? Thanks as always.
Old Mar 14, 2024 | 07:57 PM
Lawrence's Avatar
No, sorry. However, a good look with a blacklight on a dark night will usually tell you where the leak is.
Old Mar 16, 2024 | 08:25 PM
I will take some pics and try to show the progress. system was empty and ahd been for way too long. Thanks though!
Old Mar 17, 2024 | 12:55 AM
Lawrence's Avatar
Topped mine off today with some R152A/duster took about 3/4 can, went from 68 to 41, (20c to 5c) not bad for 1/2 hr's work!
Old Apr 13, 2024 | 07:41 PM
Im still poking away at getting the system reassembled. I ended up plugging the lower connection on the evaporator, hooking a short hose and funnel to the upper connection and filling the unit with my "metal cleaner/ rust slovent". I let it soak for 2 days (my schedule not the instructions) and rinsed it with several gallons of clean water till it came out clean. I have been blowing it out with compressed air every day for several days in hopes of removing all the water. So far I have the compressor, condenser and receiver drier installed. I may have got further along sooner but my truck decided it wanted some attention too in the form of the fuel gauge lying to me and making me run it out of fuel when it said there was 1/4 tank. Kah!
i must look into r152a.......
Old Apr 14, 2024 | 02:13 AM
Lawrence's Avatar
Jerry - here's my R152A guide and discussion, check out my experience.
https://forums.jag-lovers.com/t/a-c-...o-r152a/422631
Old Apr 14, 2024 | 08:11 AM
Its a very interesting idea. I know I am being "dense" here, but are you actually using the cans of keyboard duster/ compressed 'air'/ whatever were calling it? I see that the small cans of 134 are up to $20 at the cheapest and the bigger ones are about $60. Is your tap something readily available? Dont let me forget, I need to add oil to my system too.....
Also, as an aside, didnt Jaguar convert to r134a in 93? I think my 94 says it originally had 134.
Old Apr 14, 2024 | 08:42 AM
Alright, I waited 5 minutes and decided to Try to Find It Myownself! () and find that these taps are currently available on Amazon for not too much money. They look easy to use and even seem to have the correct thread.
Old Apr 14, 2024 | 10:02 AM
Lawrence's Avatar
Ok, yes, "duster" is actually pure R152A. My car was a factory R134A model. 94MY. The side can tappers are readily available and work great. Doing this from scratch, you'll need the tools, a set of manifold gauges and a vacuum pump.
side can tapper side can tapper
Old Apr 18, 2024 | 05:08 AM
Thanks, I have a vacuum pump and manifold, but was unaware of these fine accessories available to me. I am now waiting on a correct A/C muffler to arrive from Naki. It's a biggish project, I should have expected it to be both never ending and a can of worms.
Old Apr 18, 2024 | 10:46 AM
Lawrence's Avatar
Jerry -If you're going to use R152A, be aware you need quite a lot less than R134A ...proportion is in the thread I linked above - good luck!
Old Apr 27, 2024 | 06:56 PM
I got stopped again! this time, the opener on my trucks' garage door self destructed. and the oil pressure sender on the 94 was next to be replaced (a can of worms in itself) so it came in while I was waiting for the a/c muffler..... Its never ending..... But now I have a good a/c muffler and (I think) all else Ill need, so once I get back around to it -who knows, Is success in the offing? We dont dare speculate.
Old Apr 27, 2024 | 09:08 PM
Lawrence's Avatar
Good luck. Hate the oil pressure sender job btw so sympathies!
Old Jun 18, 2024 | 04:09 PM
I had gotten the system assembled at least 2 weeks ago and put my vacuum on it only to find that there was a massive leak which turned out to be the pressure cut off switch on the compressor. I ordered another and am now doing a leak down test. Hoping.......
Old Jun 19, 2024 | 06:33 PM
Wot?!?!?! No fanbelt!?!??!!?!? I was sure I had a new one!
Old Jun 19, 2024 | 11:40 PM
Lawrence's Avatar
Ahh - you just forgot where you put it ..BTDT
Old Jun 20, 2024 | 05:50 AM
I am fairly sure I had a New one waiting. I was in The Zone though and almost put an old crappy one on but realized that if I did I would never change it back off. Anyway, I searched my parts department and all I got was dirty.
Old Jun 23, 2024 | 04:51 PM
After the missing belt issue, one more should -have-been- seen hurdle was left. The low side hose that I got was an r-12 reproduction. So that last one-more-thing part I needed was a low side port adapter for r-12 to 134. I found that kit at my local Oreillys and off I went. I put the system on the vac pump again and then added one 3 ounce can of pag-100 oil, then 2 small cans of 134. I opted not to use the 512 mostly because I never got around to getting a side tap. The system seems to be working fine now (knock on wood trim) and we shall see how long it holds up.
BlownKitty
Jun 15, 2021 08:46 PM
X2002
Sep 3, 2013 11:51 PM
Rutty
XJ40 ( XJ81 )
Jun 24, 2013 08:53 PM
mike66
Nov 9, 2012 01:20 PM
Roger95
Jul 10, 2012 04:04 PM
