XJ40 ( XJ81 ) 1986 - 1994
Removing steering column
Old Feb 27, 2012 | 09:09 PM
Shelby676's Avatar
Default Removing steering column
Can't find exploded view of my '92 XJ6 Steering column. Trim pieces are off, mid way nuts removed, bottom bolts loosened near u-joint at bottom of shaft. Looks like a square metal housing Right behind wheel should come off after removing 4 - bolts with 8mm heads. That housing has several wiring connectors attached. Looks like it should move out of the way (leaving wiring attached) so I can slide out entire column. What am I missing?
Also, how to R&R ignition switch and or housing; is in two pieces clamped around column. Looks like two threaded passageways from underneath, but no bolt heads on top??
Old Feb 28, 2012 | 08:38 AM
daxter1987's Avatar
Here you go man, subscribe and bookmark my blog!!
Car Articles: 1992 XJ6 Steering Info
kevinl
Oct 31, 2019 06:15 PM
sogood
Sep 15, 2015 07:35 AM
1964Daimler
Sep 9, 2015 11:28 AM
AL NZ
Sep 4, 2015 08:39 PM
laserguy
Sep 3, 2015 02:02 PM
