XJ40 ( XJ81 ) 1986 - 1994
Squeaky sound from rear wheel
Old Jul 11, 2021 | 08:12 AM
MattsJag91's Avatar
Default Squeaky sound from rear wheel
1991 XJ40 Sovereign
so I’ve had this sound coming from the rear passenger wheel since I’ve bought the car and it’s killing me when I ride with the windows down as the noise reflects off passing cars and even the curbs on the road or driving past a fence.
It is a constant squeak/grinding that is in rhythm with the wheel itself. The noise goes away when I press the brake pedal. I’ve greased the brakes, cleaned the rotors and even the brake caliper. I even changed the pads although the ones on it were brand new. The first time I greased the brakes the noise went away for less than a quarter mile then came right back, i greased everything again and the noise remains.
my thoughts are: wheel bearing, wheel
hub, caliper?
any help is appreciated 😁
Old Jul 11, 2021 | 08:55 AM
jerry_hoback's Avatar
Could it be the dust shield hitting the rotor? Ive managed to bend mine on occasion, simply a shove with the thumb to fix.. If youre sure its not the wheel bearings themselves, have a look at the u-joints in the half shafts. Those will wear too. You said you cleaned the rotors and caliper (I think). Did you grease the slider bolts too?
I like your overall look there. Those wheels are good with the lowered stance.
Old Jul 11, 2021 | 10:17 AM
MattsJag91's Avatar
I’ve checked and the shield is clear or the rotor , I’ve also greased the pins in the process of doing the brakes. And thanks. I’m not sure if it’s the bearings or not as I haven’t done anything that I haven’t mentioned above. I read a forum on removing the actual hub itself for further inspection but sounds like a pain, I’m just curious as to why it goes Away when the pressing the brakes as the wheel continues to spin when coming to a stop . Also when I press the brake, before the sound goes completely away, it changes into a deeper tone or squeaking as if it’s brake related..
Old Jul 11, 2021 | 01:44 PM
You can jack the rear end up and spin the wheels from underneath. It will give you a much better "eye " on the origin of the sound. Maybe use a machanics' stethoscope if it's still unclear..
dtrain
XJ40 ( XJ81 )
Aug 4, 2021 01:20 PM
BruceTheQuail
Nov 12, 2019 04:03 AM
Yaseen Topia
Oct 1, 2018 10:57 AM
Lubino Do Rego
Jun 3, 2016 03:09 PM
ChrisB
May 13, 2011 09:41 PM
