XJ40 ( XJ81 ) 1986 - 1994
Stability Control Relay
Old Jul 27, 2017 | 08:19 AM
WattsXJ's Avatar
Default Stability Control Relay
I have been looking through the XJ40 handbook and it shows the relay in my book, but I can't find its specs.
Was looking to replace it as the one in the car is missing,...
I am thinking that a standard 4 pin relay with 40 amps capacity should do?
Unless it is a 5 pin or so.
Just wondering what the specs should be for it?
Or if someone knows the correct specs.
Old Jul 27, 2017 | 09:47 AM
motorcarman's Avatar
There is no Stability Control in the XJ40. There is ABS. (Anti-lock Brake System)
There are 3 relays listed for the cars From VIN (594576) in the JEPC.
#2 Reverse inhibit relay, Green, DBC2483 (superseded)
#3 Main relay, rear seat pan, White, DAC7151
#4 Relay, Yellow, DAC4506
bob
Old Jul 28, 2017 | 01:15 AM
WattsXJ's Avatar
Good news for me then.
I noticed the relay was missing from the boot, with the label "stability control".
Next to the antenna up, and down relay.
Must be the same part and they just rolled them out in every vehicle.
twack
Oct 19, 2016 03:59 PM
twack
Oct 19, 2016 01:33 PM
Timothy J. LaPean
Oct 17, 2016 03:44 PM
racerx82
Jul 18, 2007 09:50 PM
Mar 16, 2006 03:10 PM
