XJ40 ( XJ81 ) 1986 - 1994
Stalling occasionally now it's FF44 time!
Old Jan 12, 2016 | 10:29 PM
manwich66's Avatar
Hey Larry,If the sensor were all warmed up, the voltage would swing. An air leak upstream in the exhaust will/ could cause the same kind of thing.You should see the guage swing wild tho...
change the sensor...
Cheers,Jim
Old Jan 12, 2016 | 11:11 PM
Lawrence's Avatar
Originally Posted by manwich66
Hey Larry,If the sensor were all warmed up, the voltage would swing. An air leak upstream in the exhaust will/ could cause the same kind of thing.You should see the gauge swing wild tho...
Cheers,Jim
Waiting on delivery Jim ..btw, the Fluke meter was duff so used my Canadian Tire unit ..at least it works!
Gonna do some more tests tomorrow
Larry
Old Jan 13, 2016 | 06:04 PM
Lawrence's Avatar
Thumbs up update3
Well today I'd planned to do some more tests but as I was running a bit low on gas I drove over for a fill up first.
Surprisingly, she warmed up and apparently went into closed loop without a problem as no codes or MIL warning came up - plus - didn't have any stalling/surging issues either ...
Anyway, drove around quite a bit, about 10 miles or so, stopping and starting at various places around town and still no weirdness or codes
No doubt this is a temporary situation but looks like everything is behaving itself again?
Larry
Old Jan 13, 2016 | 09:44 PM
Don B's Avatar
I think I recall reading in the Diagnostic Manual that the ECM won't do certain things if the fuel level is below 2.5 gallons. But maybe it was that it wouldn't trigger certain codes if the fuel was low? I wonder if that had anything to do with your issues?
Old Jan 13, 2016 | 10:12 PM
Lawrence's Avatar
Yes Don, I read that too and wondered the same thing!
However, after I filled up I ran around for a good hour and a half, stopping and shopping for about 20 mins in between and she ran just fine.
Maybe I have a weakness or break in the o2 sensor harness that somehow got re-oriented into a better connection after I horsed around with the wiring doing all that testing?
I'll take her out for a run on the highway tomorrow and see if she still throws a code.
BTW, talk about being stupid! - It seems as though my purge valve test wasn't a purge valve test at all!!!
I have always assumed the skinny striped hose that connects to the vacuum tee toward the front of the intake manifold was the purge valve hose. In fact, it's the connector to the vacuum control valve.
So in my my purge "test" I connected up to THAT hose - so that's why it failed the "test"!
To my embarrassment I have to admit I still don't know where the purge hose connects to the manifold.
Thanks for the input as always Don
Larry
Old Jan 14, 2016 | 12:22 PM
Don B's Avatar
Don't be hard on yourself, Larry. The carbon canister system is not explained very well in the documentation, especially its plumbing.
IIRC, the purge valve hose connects to the left or forward side of the EGR port on the bottom of the intake manifold. The EGR pipe connects to the right or rearward side of that port. I show some photos of the port in this album:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
theshortwhiteguy
Jan 10, 2016 05:29 PM
pdowning6
Oct 13, 2010 06:21 PM
shortbus76
Sep 25, 2010 07:26 PM
hankycbr
Oct 28, 2009 01:42 PM
