XJ40 ( XJ81 ) 1986 - 1994
starter removal
Old Mar 2, 2012 | 04:15 PM
bert_vdp's Avatar
Default starter removal
I don't know if anyone has posted on this issue or not. I wanted to know what the easiest way to remove the starter on a 91 xj6 would be. I have done it on my series III but this is a much tighter fit, any tips, or special tools needed?
Old Mar 2, 2012 | 09:02 PM
Lumppy47's Avatar
One royal pita. On my 90 i removed the intake manifold.so as to get some working room.Then i used a 12 corner box end wrench which i bent to get the bolt from the backside of the bell housing (not a lot of room to work with).The other bolts come out easily.If and when i do it again i also would make the wrench longer for more leverage. I think this way is easier than having to do it as the hanes manual suggests.Also dont forget to disconect the ground from your battery.
aholbro1
Dec 29, 2024 06:46 PM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
TC Johnson
Sep 2, 2015 09:30 AM
