XJ40 ( XJ81 ) 1986 - 1994
Suspension part
Old Sep 24, 2017 | 08:14 PM
sejone63's Avatar
Default Suspension part
Hello I have a 1989 xj40 vanden plas. I noticed the other day when I was under it that my lower control arm crossmember was bent. I am having trouble locating another one. Can you help?
Old Sep 25, 2017 | 04:09 AM
Robman25's Avatar
Hi this needs to be in the XJ40 thread. Can you post a photo to show the extent of the problem?
Old Sep 29, 2017 | 05:24 AM
Welcome to the forum sejone63,
I've moved your question from Mark V - X 420G to XJ40 forum. This is the place to post questions about your model.
Old Sep 29, 2017 | 02:15 PM
frenchfairplaydriver's Avatar
good evening, on the diagram, what would be the twisted piece?
Old Sep 29, 2017 | 02:18 PM
https://www.jaguarclassicparts.com/f...e-differentiel
Old Sep 30, 2017 | 10:05 AM
Don B's Avatar
Hi sejone63,
It will certainly help us help you if you can answer frenchfairplaydriver's question about which part is twisted. Part 1 in the diagram he posted is the rear control arm or wishbone.
In the diagram below, Part 14 is the subframe (also known as the crossbeam or mounting frame). Part 1 in this diagram is the "wide mounting bracket."
A great place to find diagrams like this, as well as part numbers, is jaguarclassicparts.com, the parts service of the Jaguar Daimler Heritage Trust.
Parts like these are no longer available new from Jaguar, so salvaged parts are typically the only option, unless you can find new old stock. I try to find an eBay seller who is offering parts from the same model and year, and use the eBay message system to contact the seller to ask if he or she has the parts I need.
Cheers,
Don
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
goodgame
Oct 21, 2016 09:33 AM
MickJagguar
Oct 4, 2016 04:26 PM
JimC64
Feb 13, 2014 07:35 PM
bojangles
Dec 3, 2006 09:07 PM
