XJ40 ( XJ81 ) 1986 - 1994
Trunk Lock Issue
Old Aug 22, 2024 | 12:44 PM
etaent's Avatar
Exclamation Trunk Lock Issue
Hey guys got a weird one here. So when I first got my 1992 XJ6 Sovereign, the trunk lock worked intermittently. Sometimes it would activate the lock when I locked the car, and sometimes it wouldnt and the trunk would be accessible despite every other lock being secured.
In my quest to make the car perfect, I decided to put some white lithium grease in the key hole to lube it up. Now, the lock works perfectly every time. The only concern I have is that now it makes this horrible sound when unlocking. I have included a video for you all to hear.
Should I be concerned? Is this a normal sound? Any idea what it could be and how to address it if it is not?
Thanks in advance!
File Type: mov
Old Aug 24, 2024 | 06:31 PM
jerry_hoback's Avatar
Mine makes that noise. Its the lock actuator. I took mine out to see if I could fix it but the unit has plastic gears inside. I think theres a place that rebuilds them but I havent had that problem rise high enough on "the list" as yet.
Old Aug 26, 2024 | 08:25 AM
etaent's Avatar
Do you know the place that rebuilds them?
FredA101
Mar 18, 2022 04:11 PM
losfinch
Dec 3, 2021 07:26 AM
MIFoodie
Nov 13, 2017 05:45 PM
JayCee
May 23, 2016 06:36 AM
jagyankee
Dec 21, 2013 06:50 AM
