XJ40 ( XJ81 ) 1986 - 1994
Twin xj40 engines on the dyno
Old Dec 17, 2019 | 07:02 AM
ivanhoew's Avatar
Default Twin xj40 engines on the dyno
Hi chaps , finally got my megasquirt injected lpg twin engined monster running on the dyno ..
7.6 litres of 48 valve goodness .
regards
robert
Old Dec 18, 2019 | 08:34 AM
Mike Martin's Avatar
Wow. You definitely have my attention.
Excellent work on this. She sounds amazing in the video. I can't wait to see the road-test footage!
Old Dec 18, 2019 | 09:19 AM
motorcarman's Avatar
I'm proud to have contributed in a small way!! Glad it functions properly!!
Old Dec 18, 2019 | 02:22 PM
Don B's Avatar
Robert,
It's a beautiful beast, and I can't wait to see it in motion!!!
Cheers,
Don
Old Dec 18, 2019 | 02:34 PM
ivanhoew's Avatar
Thanks Mike , bit of footage should be sorted pretty soon
THANK YOU ..You definitely did !!
interestingly , those seals you so kindly sent me , cleaned up the 3.6 brilliantly , however the 186,000 mile 4.0 was a proper smoker even after fitting them , so i used an old trick, i connected the inlet vacuum stub to the engine breather with a t piece, the other leg of the t piece went to a 22mm one way valve from the plumbers merchants .
this way , at high inlet vacuum i have the same vacuum in the sump as above the pistons and inlet valves , so the oil stays where it is , and on full throttle any sump pressure is allowed out through the 22mm one way valve ...this cleaned the engine exhaust up so much, i used it for the emissions test on the mot and it was fine .
i am guessing the oil control rings on the 4.0 are stuck .
regards
robert
Old Dec 21, 2019 | 11:29 PM
Brewtech's Avatar
Wow! Thats insane! Love it
Old Dec 22, 2019 | 02:13 AM
ivanhoew's Avatar
Thank you Don , and Brewtech ,much appreciated
Philly Single
Jul 9, 2020 06:35 PM
JensenHealey
XJ40 ( XJ81 )
Mar 22, 2019 12:35 PM
malibudav
XJ40 ( XJ81 )
Mar 2, 2012 03:56 AM
MidwestJag
XJ40 ( XJ81 )
Nov 11, 2011 03:19 AM
alexsneesby
XJ40 ( XJ81 )
Oct 13, 2010 04:55 AM
